Is It OK to Mix Diff. Fluid?
I wouldn't. The chenistry and add pack are totally different. Why not just do a drain and fill? All you have to do is open the drain plug and then refill.
If you're low on fluid, then topping of with any like fluid is perfectly OK and definitely better then being low on fluid.
Since low sometimes means overdue for a change, then by all means maintain that 'end.
I've mixed diff fluids on my ranger cause I was cleaning out the diff cabinet of all the half filled bottles. They were all 80w90, same specs all convential fluid. I don't have any problems. Then again it's my winter truck and anything else I'd just put all the same fluid into it.
