- Joined
- Jun 2, 2003
- Messages
- 23,591
They are supposed to use the wife's car, of course.quote:
"what are BWM M3/M5/Enzo Ferrari driver's supposed to use in severe cold?"
I forgot to mention that, as CT still does sell a 5w50 synthetic, now it's under their Formula 1 brand name. Their oil is made by Shell.quote:
Originally posted by 2K2AcuraTL:
Canadian Tire had a 5W50 synth weight in late 1999, under the CT label. Havent seen for a while.
J
Their Honda Civic.quote:
Originally posted by Dr. T:
Guess this oil would answer my question: "what are BWM M3/M5/Enzo Ferrari driver's supposed to use in severe cold?" (ie. when a 10W isn't adequate)
I don't think I'm following you here. How about using some actual numbers and explain what you're getting at.quote:
Originally posted by Gary Allan:
Well ..then (and thank you btw) that makes the existance of a 0w-60 impossible UNLESS you can truly have a fluid get heavier at a higher temp. That is, the bottom end of 5w (which 0w would be assumed to be below) is lower then the lowest 60 weight "weight".
Well, if you look at 5w and assume (and I am assuming here) the 0w is below that spec, it falls somewhere at or below 17 CST @ 40 C ..yet 50 appears to peak out at around 19 CST @ 100 C. That means, if I read the chart correctly, that a 0w-60 would have to be heavier @ 100 C than it is @ 40 C. That is, it would have a viscosity increase at a higher temperature. This would truly make it the "Holy Grail" of oils ..thinner when cold ..slightly heavier when hot.quote:
I would think that given the right base oil, a 0w60 could be entirely possible.
Okay, I see what you're talking about now. Here's where you're making your mistake: You are assuming that a 0w60 oil would have to have the the vis of a 0w at 40C. It wouldn't. It would have to have the vis of a 60 wt at 40C. It would have to have the vis of a 0w at the J300 cold cranking and cold pumping test temperatures of -35 and -30. In other words, a straight 0w oil is always going to be thinner at 40C than a 0wXX oil.quote:
sprintman, I believe, sees what I'm saying here.
