irritating problems and issues on a used car for sale
I USED to have that opinion. I work with a lot of Phd researchers that would ask me to change their lawn mower spark plug. Really?????
They would get back to their work analyzing stats and high level projects (something I cannot do) at double/triple my salary.
I stopped judging them. But yes, being self reliant is a valuable skill.
You should not judge them. If they are good enough at their job, and that takes time and effort, they get paid enough to have someone else maintain the outside of the house or the equipment.
Battery hold downs MIA
But, most people never open their hood, so......
One of the first things I noticed required immediate fixing when we got my son’s Honda. Couple large zip ties and Jerry rigging the broken but still usable tie down rod and it’s good to go. The small center one is easily snipped off and replaced if need be.
I was able to pick up this vehicle for him and from what I can tell I think the previous owner was done messing with it. All dealership or quick lube serviced. $500 in DIY repairs over a few months and it’s a much better vehicle now. God knows what that would have cost at the dealership.
Sometimes it's money (Even a $100 is a lot to some people.)
My sons rear driver side regulator failed in his Santa Fe. Found a used one for $160 or so. New was nearly $600.....
The job was, not easy. It was challenging. Most people wouldn't have done it themselves (I know we here on BITOG would, at least a lot of us.)
How is window regulator that much? I've replaced them at least 6X on my 1999 Alero and they are really cheap.
Maybe it's just my screen as I'm looking at it in the sunlight, but that brake fluid reservoir looks low.
I was thinking about that this morning. So the person goes to a title loan or payday loan place to borrow $500 to get the car running. The one with the continuous annoying adds says a $500 loan "only" costs $2.75 per day. How about putting that $2.75 per day in a savings account now. Six months and you have $500 in the bank for that rainy day.
Just make it one of your monthly payments. Keep at it and have $1,000 after a year (with no calamities). How about it? I have been adding to my rainy day account since 2009. The balance is substantial.
I was going to guess it might be like 4th Gen Rams and GMT400s where effectively the entire inner door "subpanel" is the regulator.
I watched a vid for an '07-09 Santa Fe rear window regulator and that appears to be the case. Now, you can get 4th Gen Ram ones delivered for ~$120 or less (aftermarket), but I'd imagine it's just supply & demand. Think about the number of 4th Gen Rams you see vs any Hyundai Santa Fe on the road on a given day
Every single "hobby car" I've bought had an oil leak or multiple oil leaks, something I refuse to live with. I cannot stand an un-potty-trained car dripping on my driveway. Sometimes they seem impossible to get sealed up by any means short of pulling the engine and transmission and putting new seals in everything. And why is it impossible to design and implement a rear main seal that never fails? We put a man on the moon....supposedly. Why can't something be done to stem the extreme downtime and expense of replacing these? And to the auto manufacturers in the '80s that designed components on engines that are sealed only with RTV, when they could have been designed to use a gasket...... I have a hand gesture for you.
'82 Mustang 3.3
'85 Laser Turbo
'86 Fiero GT
'93 Sundance Duster 3.0
Interesting design, and definitely not mechanic friendly!
I was surprised myself. Used they go for about $160. New was almost $600........
2019 Santa Fe SE 2.4L. Drivers side rear. Check it out. The job was NOT easy either.........
  • Like
Reactions: D60
Correct. Basically the whole sub-panel, which sounds like an easy repair/swap, but it's a TIGHT fit, and getting everything lined up with the window and securing it was tricky. I made up a few words. Mormons skip our street now.
I have purchased lots of used cars, and I have learned that cosmetics make the biggest difference to most people. If the car is clean and shines sellers ask more, and if you try to negotiate on mechanical issues they are dismissive. Look for the grungie cars if you want deals. And despite all claims to the contrary, you can't judge a car by looks. The spit and polish often covers up mechanical defects.As to window regulators--I've changed a few and some are real bears to get at, meaning an expensive repair if you are paying a shop. Same with other simple stuff like heater cores, batteries, air filters, etc. I had to take off most of the front of a Subaru to replace a cracked washer fluid tank.
Most people don't care.
100%. I work alongside a pretty diverse group in multiple cities. Recon I grew up in a vacuum and my Father was a car guy. But ****... a LOT of people do not care one bit what they drive, how it looks and are really lax on maintenance. I notice dented body panels, messed up trim, mismatched wheels and tires worn down to the cords daily. They don't even see it
Heard one person complaining about having to remind the spouse again about using the 1 gallon jug of oil in the trunk to top off the engine oil every time the oil light on the dashboard comes on o_O chew on that for a minute.
How about you? Have you bought a car with a problem that made you think, "I can't believe they have been driving it like that - I will have to fix that IMMEDIATELY!" ?
2001 Ford Taurus SEL with Vulcan engine, former Hertz.
We probably went back to the dealer 5 times to fix everything including roof leak, plastic switch for headlight broken, plastic sway bar end link broken, plastic cover over wiring harness warp, warp brake rotor, hairline crack in spark plug at 40k miles (double platinum so it should last at least 60k), valve cover gasket leak at 50k, blown fuse after a car wash at 30k, burping ATF at 70k, etc etc.
None of them are wear and tear or environmental. I blame it on manufacturer sending a half finished car to a rental car company they own as dumping ground.
If those are your biggest issues then count your blessings as you’ve been very lucky.
Yes, a lot of people don’t care about cars and as long as the wheels are turning, they don’t care about fixing the little timings on old clunkers.
Take advantage of this when negotiating and thank the universe such people exist, otherwise you would not be able to find good deals on used cars as everyone would think they have a gem in their possession.
My recent experience is they don't care about the blemishes, they still think they have a gem. And these cars sell so apparently they convince someone.
The insurance company doesn't care if its a gem either - they still pay out the lowest. Learning this in real time.
