IPOD Mini surgery:battery replacement
Fayetteville, NC
As one of my spring break projects, I thought I'd replace the battery of my wife's old ipod mini, which wasn't holding a charge anymore...one can do this for about $60 by sending it to various ipod battery replacement services, but I thought I'd give this a try, and got a higher powered ipod mini replacement battery from amazon...there are even higher powered ones, but I wanted to make sure that I'm able to perform this daunting surgery first, so I got one of the least expensive higher powered batteries from some place on amazon.com...it only cost me $12.00 for it, and even that is higher capacity than oem apple battery...
now that I know how to do it, next time I can try one of the higher-end replacements...if i ever need it.
I used this guide to help me with the task:
http://reviews.cnet.com/4520-11293_7-6378822-1.html
this is what the replacement battery came with...1 flat head screwdriver to open the plastic top/bottom of the ipod, and a phillips screwdriver to take the two TINY screws off...this screwdriver was too small for the screws on the ipod: I had to use one that I had in my tool box.
It was (as expected) harder than in that cnet guide: really a PITA to get the top and bottom plastic covers off...heating the sides with a blow dryer and getting the glue soft/melted helped a lot. the bottom side has a metal clip which again was a pain to get off, but with much prying and pulling, it came off: remember to disconnect the click wheel data connector before sliding out the ipod guts (from the top)
i-pod guts: click wheel side:
closer look:
a look at the back side, where the battery is: (old battery shown)
Old battery out, new one in
sliding everything back in was a bit tricky, but with a lot of patience and steady hands, it is doable.
after connecting the click wheel connector, and putting back the metal clip (bottom) and the 2 plastic covers...
It's alive :) :)
test to see if the click wheel still works (it does, in my case), charge the new battery for 3 hrs before use.
It took me about 25 min. to do it all, and if I can do it, most people here can, i'm sure...:) for $12 and 25 min free labor, a higher capacity battery is not bad, I think. Like I said earlier, there are even higher quality/capacity batteries on the net for more $$.
Awesome job! I was thinking of doing this to my girlfriend's old Mini. Then she bought both of us new Sansa's!
hehe...yeah that does look funny, BUT:
the tape is not actually "holding" the HD. It just holds the blue padding stuff that's around the HD. the HD is just lying there...there's hardly any room to move, so "holding" it is not needed, probably.
update: the battery works great btw...the old one hardly worked anymore...it took me about 7 hrs to run the new one down last night. :) so I guess it worked out well..
