iPhone 14 vs 17?
NH
Daughter (who's in college) managed to kill her iPhone. No idea why but it won't power on. I guess the wife has been thinking it was time for a new phone anyhow? but now the phone has forced the issue. Anyhow, wife found a refurb 14 on Amazon for $460 and apparently a new 17e is $600. I know next to nothing about these phones but I'm thinking it's best to go new. Warranty and most likely to last longer (maybe). Thoughts? The daughter isn't hard on things--but has the worst luck with electronics (stuff just quits working).
On a side question, how do these electronic SIM cards get switched between phones? Do you have to go to whatever Apple uses for a web portal? My iPhone has a tray for the SIM and IIRC I was able to switch to a nano SIM last time I changed phones, but I guess next time I upgrade I'll have to understand this a bit more.
I can’t remember ever touching a SIM card on any iPhone. My upgrade path is go to ATT store, pickup the new phone, they activate it and I sign into iCloud. Go home with both and once iCloud is done syncing (typically a few hours) I just return the old phone (if <2 years old) or for the times I keep it longer than 2 years and its paid off in full I just keep the old phone, no return necessary.
I wouldn't touch those "refurbished" models on Amazon (eBay, etc). That can mean they cleaned it with an alcohol wipe and reset it to factory defaults. That battery could be ~3 years old and garbage. Even the carriers do this. Unless it's refurbished and sold directly by Apple, run away.
The SIM "swap" is handled by your carrier, not Apple.
I have no qualms with buying a refurb (both of my last iphones were refurbs), but I wouldn't go for the 14. That one's known to be a weak entry into the iPhone lineup.
Also, the 17e will have 3 extra years of software/security updates compared to the 14.
I've done a couple of battery swaps on iPhones and it's usually a pain but it wasn't too bad. Unlike my iPad which was harder. Next time the iPad needs a battery I plan to just trade it in / replace altogether, as the last couple of times it had slowed down drastically at the same time (4 years old?). As to refurbs we've done a couple and it was ok. I think the batteries did have to be replaced in short order though.
Anyhow, wife seems to have decided and wants me to pick up a 17e tomorrow. So I'll have to swing into the Apple store and pick that up, and she can figure out how to get it onto Tracfone.
Can confirm, I did a few of our company's last year via vz's website. I think I only needed the imei of the phone.
For consumer level, specifically if you're UPGRADING a device on an existing line, it's even simpler. When you call, their automated system prompts you with "are you ready to activate your new phone?" or something similar to that. You basically hit "1" for "yes" and it takes care of the rest.
I'll see what the wife complains about. Not the first time she's switched phones so I'm guessing she is familiar. I don't remember what it took to switch last time as my SE has a nano sim in it.
This is the only place I would buy a refurbished phone if I ever was to buy one. Direct from Apple.
Apple warranty, all new outside case, new battery. Apple states just like new.
https://www.apple.com/shop/refurbished/iphone
Apple iPhone 13 and SE (3rd Gen) are last iPhone with physical simm port as FYI. In short if free or own use them don’t buy those.
Not sure I am understanding/
iPhone 13 supports physical and eSim if you have a physical sim port. There is no reason to avoid them.
Overseas many iPhones 13 and later still have dual sim support, physical and eSim. iPhone 16e is the first iPhone to ship world wide without a physical sim port.
If you really want a used one, find a well cared for one on Swappa.
I sold my wife's old 15 Plus on Swappa for $400 and it's leagues better than that 14 you were thinking of getting. It had been in a case with a screen protector it's whole life and the battery life was still great. Better battery life in fact than the brand new 17 Pro Max that replaced it.
I'm still using a 10...I just don't load it down with updates anymore...still works great!
The 17e has been working fine for a week now. I'm not sure what the dead iPhone is but I haven't had luck opening it up yet; didn't apply enough heat to open it. Tough bugger, I don't remember the last one being this bad. But no real loss since it's dead, so I might try again.
This 17 seems larger than my SE and I'm not sure I'd want one. The daughter didn't either but it was this or none.
My (youngest) daughter just yesterday got a 17e. What are a few top differences from a standard 14 => 17/18?
I ask this way because my 14 battery is struggling a bit. New battery or 17e or ??
