I was cruising through some of Honda's older 'ServiceNews' documents that they put out monthly. I stumbled across a bit of information that you all might find interesting.
This was pulled from the Sept. 2002 issue:
Can a Small Oil Filter Be
Replaced by a Large One?
For all Honda models, the answer is YES. The 65
mm diameter oil filter is directly interchangeable
with the 80 mm diameter filter. Both filters use the
same filtration media to do the job, and filter out
at least 70 percent of the particles that are 30
microns or larger, and 85 percent of the
particles that are 40 microns or larger.
• Large filter: P/N 15400-PLC-004,
H/C 6475834 or
P/N 15400-PLM-A01,
H/C 6446231
• Small filter: P/N 15400-PT7-005,
H/C 3630399 or
P/N 15400-P0H-305,
H/C 4908182
H/C 6475834 or
P/N 15400-PLM-A01,
H/C 6446231
H/C 3630399 or
P/N 15400-P0H-305,
H/C 4908182
