OVERKILL
$100 Site Donor 2021
So, now that the Jeep seems to be fixed (it also has a new alternator it didn't need) I've been watching the voltage to confirm. Problem was a loose main body ground near the battery.
Some quick data: Vehicle has a 220A alternator which appears to be made by Denso. Battery is a factory AGM situated beneath the passenger seat.
Upon initial, and most starts, charge voltage sits around 14.6V, usually going no lower than 14.5V and no higher than 14.7V.
HOWEVER
Some starts it will sit around 13.5V and go no lower than ~13.4V, no higher than 13.6V.
Next start, it will be back at 14.6V.
I've noticed this primarily occurs on a hot start after you've driven it for quite a bit. However, I've not noticed it step down to this voltage range while in use. It seems to take a stop/start cycle for this to occur.
I'm guessing it may have something to do with battery health charge programming but that's based on nothing. Dealer has no idea, thinks it might be what I'm thinking. No idea if it has always done this, as I was not constantly monitoring the charge system prior to these recent issues.
Thoughts?
HOWEVER
Thoughts?
