- Joined
- Feb 6, 2025
- Messages
- 817
Battery was at 12.0V on a cold start this morning. After idling a couple of minutes, it drops down to 11.9V and then a minute later to 11.8V. At 11.8V the "Check Charging System" comes on the dash. A few minutes later while still idling and the engine dropping from fast idle to regular idle, the battery voltage jumps to 14.7V. After 10 minutes of idling, the water temp is at 194F and the battery charge state holds steady at 14.5V. Dash says "Battery Voltage Normal." Battery is about a year old from Costco and the alternator is the original GM unit from the 2000 production year.
