Gentlemen I have a 68 Torino (nice) running the original 302 block equipped as follows--0.060 over with TRW forged pistons,Hastings rings, full Edelbrock equipped, heads, manifold, 600 Cfm carb,218/228 cam with 114 deg. LSA, headers, balanced and dual point dizzy. The compression is excellent and the engine has been using Mobil 1 10w30 and Redline SI-1 from original start-up. I had occasion to remove the intake today (after approx. 9000 mi.). I checked ALL of the intake valves with a scope and was a bit underwhelmed. The deposits are less than one would expect with straight gasoline but still present. The guides show no apparent oil seepage and the lifter valley was'nt passing oil. The deposits are concentrated on the underside of the valves and average about 1/16-3/32 in. thick and are very hard. I am a bit anal about intake valve deposits and will continue to use some additive. I don't know if I will stick with Redline. Best regards. John--Las Vegas.
