Grr. So I checked the oil today on the villager, down 3/4 of a quart. Looked at the oil pan, had oil covering it. Looked under the hood, and found oily residue with dirt in it so it was like that sandy paste. I think its the intake manifold gasket leaking but I have never done one. I'm putting some pics up. It looks to be leaking on the screws holding the black 6 cylinder tubing. If it is the intake manifold gasket, do I need two of them and the one gets sealed to each side(manifold and w/e manifold goes into) and then they get tightened together or it just one gasket? Thanks guys. Also what is the metal wire thing going over the manifold and do I need to remove it?
