Kestas
Staff member
Our client (a supplier to the NASCAR racing groups) has a problem with their set of third gears. They are scoring on the pressure side of the teeth - not pitting or abrasive wear, but scoring. The pattern of scoring is such that wear is only in the negative sliding region of each tooth (dedendum of the driving teeth & addendum of the driven teeth. The positive sliding regions look okay... there's evidence of meshing and light burnishing on the rest of the tooth. Full engagement of the tooth width is evident, so there is no misalignment in that direction. Lubrication is forced onto the teeth.
We're thinking this is a lubrication issue. The lubricant used in this application is 75W-90, probably Mobil SHC. It seems the oil can't keep up with high rpms of the gear box and we're losing boundary lubrication. There's thought that there may be some misalignment during operation, i.e., deflection in the gear box causing slight separation of the gears, but I'm not convinced this is 100% the answer, or even 10% of the answer.
What can we do to specify a better lube to handle the brutal requirements of speed, load, and temperature?
