DSteven
This evening, on the 97 Stratus, I tapped into the trans cooler line, hooked up a hose and started the engine, letting as much fluid flow out as possible until it stopped. 7qts were pumped out, so I refilled with 7qts of Castrol Mercon-V. WOW! The transmission doesn't shudder, the shifting is quicker and A LOT more smooth! I am very amazed! After some miles, the trans pan will be dropped and a new filter, gasket and drain plug will be installed, which are already purchased, and the refill will be more Castrol Mercon-V! It has been a test, but so far I can certainly observe differences and they have been VERY pleasing! The 93 dakota has been driving much better, also. I hope the positive results continue with the Dakota and Stratus. For good measure, I will install a bottle of Lubeguard-Chrysler additive with the upcoming service. For what it's worth, using Mercon-V in these Chrysler transmissions requiring ATF+3 has been quite a nice experience! If a failure occurs, I will definately post. lol.
