Hi folks,
I'm looking into doing a bit more shadetree mechanic-ing than just changing the oil, oil filter, air filter, etc. Ideally, I'd like to most of my own service, as it would likely save me money, gives me something interesting to do, and I don't have anyone to blame but me
I've got a copy of the shop manual for my 2006 Toyota Camry, and was thinking about getting a Haynes manual as it seems a bit more geared for the DIYer. Good idea?
But I digress. I was looking through the Toyota-specified service recommendations, and they include such things like "Inspect ball joints and dust covers" and "Inspect steering linkage and boots". What, exactly, is one looking for here? Damage to boots, leaking fluids/grease, etc. should be easier to spot, but is there any more specific things one should do?
In the steering linkage inspection section, the shop manual mentions things like "Check if the tie rod ends do not have excessive play" but do not define (or I can't find where they define) "excessive play".
Similarly, they say that one should tighten bolts and nuts on the chassis "if necessary" -- I trust that it's not necessary to go around and attempt to tighten every bolt and nut on the chassis, right? It seems that with the build-up of road grime and whatnot, the nuts and bolts stick together more tightly, rather than get loose.
Much of the shop manual details teardowns and overhauls for the various components, but doesn't really indicate when it's necessary do to such service -- I trust it's when the part fails inspection in some way, rather than on a time/mileage interval, right?
Is there anything in particular that one should inspect on a regular basis (e.g. at every oil change)? Anything one should inspect on a more extended interval (e.g. every year or two, but not at every oil change)?
Thanks!
Thanks!
