It seems that you can convert your petrol car to a diesel, as well: http://www.greendieselcorp.com/
Hummers are getting this technology now!!
Quote:
diesel does not need spark plugs is everyone here stupid
Quote:
At 160,000 psi, the fuel would come out so fast it would burst into flames from air friction, like a shooting star.
Quote:
Much of the strain in a diesel engine is due to the nature of the combustion. The diesel knock you hear is the droplets of fuel all reaching combustion temperature at the same time. It is not nearly as smooth of pressure wave as in a gas engine. The new diesel engines run quite because they have figured out how to control the burn with multiple injections. The new Mercedes engines use 5 injection events for each power stroke. They are so quite that it is hard to tell they are not gas engines.
If this new injector can accomplish this by using higher pressure then I think it would be possible to make a gas engine run quite a while on diesel fuel.
But I do sense a problem here in that the tensile strength of steel is close to the pressure they claim for injection.
