India's Tejas fighter crashes at Dubai Airshow
From the linked story: "The homegrown jet, whose name means 'brilliance' in Sanskrit..."
Ironic name for prototype fighters, one of which had a crash last year too. Maybe the name refers to the explosion when they crash.
I watched the video, but did not study the crash. Looked like the pilot expected to perform a high G pullout. And I'm guessing the airframe had other ideas. So my initial guess is pilot error on some level.
I just found a decent video. I’m going with 100% pilot error.
He went from a negative G push, to a roll, but during the roll, he was pulling back on the stick, loading the wing.
When a wing is loaded, that is when the wing is under high angle of attack and generating high, G, the roll rate is greatly reduced.
When you’re inverted, and the roll rate is reduced, your nose gets a lot farther below the horizon.
In an unloaded roll, your roll rate is much more rapid, and the nose doesn’t drop, so, your nose stays much closer to the horizon, you do not generate as much of a rate of decent, and the pull out is much simpler.
Less altitude is required for recovery after an unloaded roll, than after a loaded roll.
But when you’re low, the instinct is to pull back on the stick, and it appears that’s what happened, and it appears that loading slowed the roll rate enough that he couldn’t complete the maneuver with the altitude he had remaining.
All preliminary, of course, but the aircraft exhibited a very good roll rate in previous maneuvers. Unfortunately, during this maneuver, the roll rate was slow, which tells me he was rolling while pulling back.
So, pilot error.
Apparently this can be a dangerous maneuver to perform due to the possibility of G induced impairment.
It’s the rapid transition from negative G to positive G that is the issue.
This guy lost me when he said that the Blue Angels intentionally apply G to make people experience GLOC.
They do not, I can assure you of that. That kind of offhanded, derogatory comment, takes away from the point he’s making. Why take a swipe at an organization with which you’ve never served, based on some rumor you heard in another country’s military?
However, GLOC is why fighter pilots undergo centrifuge training.
Prior to full on GLOC is “gray out” in which your retinas, deprived of oxygen, stop perceiving color. It takes a tiny bit more blood pressure to get blood to your retina than it does the rest of your brain, so if you’re right on the edge, you’ll lose color vision.
Fighter pilots also wear G-suits in flight (except for the Blue Angels, and I have covered that before).
However, in the centrifuge, we do not, making it much more difficult to sustain G, and thus, better asses and train a pilot’s ability to manage high G. I mentioned that in this post:
Post in thread 'Has the FAA ever forced an airframe into retirement?'
https://bobistheoilguy.com/forums/t...-airframe-into-retirement.401824/post-7431107
This guy does notice, as I did, the slow roll rate, which he attributes to the vasodilation from the negative G.
