This was a Blackstone analysis, correct?
I'm surprised your flashpoint (385) is as high as they are claiming considering your fuel dilution is reading at 2.0
Blackstone uses an "open cup" method for determining the flashpoint, a process I've heard is not nearly as accurate as the "closed cup" method. I'm willing to bet if your fuel dilution is truly at 2.0, your flashpoint is more likely to be 280 to 290, not 385.
What's interesting to me is that the lead jumped higher with the fuel dilution level but the iron and copper trended mostly at the same levels.
Some random thoughts: if you switch to the 7000 (or any other oil), run that same brand/weight for at least three separate OCIs before you sample it for a UOA. As alluded to by Doug, "one-pass" UOAs really tell us very little. You'd need three OCIs to ensure any UOA on the 7000 is not reflecting "leftovers" from the 9000.
In my 2001 Infiniti I30 (3.0L V6 - I know, completely different engine), whenever the fuel dilution spikes, so does the lead levels. Most of the other wear metals stay constant, but the lead jumps off the UOA page.
