Improvised cap wrench
When installing a filter on my Subaru engines, I like to use a cap wrench to install them.
I can already feel a lot of you gearing up to tell me you don't need a wrench to install, and I know you're right, but hear me out first. I have two reasons. First: I have tendon problems in my wrists, and hand tightening a filter puts my hand and wrist in just the right (or wrong, I guess) position to aggravate that condition. Second: It's way easier to do exactly the specified amount of tightening (3/4 turn, 1 full turn, whatever is called for) with a handle or bar than it is to gauge it by hand. Satisfies my OCD.
Now to the point. I bought a dozen Champ filters for these engines, and I can't find a cap wrench that fits them. So I made one that fits:
This is an old cap wrench I bought for a car I might have had 30 years ago. I wrapped one of the Champ filters in Saran Wrap, lined the inside of the old cap wrench with JB Weld epoxy putty, smushed the plastic-wrapped filter into it, and let it harden. It fits the filters perfectly, and as a bonus, the JB Weld didn't stick to the Saran, so I was able to peel that out cleanly. It's a little funny-looking but it does the job. Probably wouldn't hold up to being used for a lot of removals, but to tighten that 3/4 turn it's just fine.
It's been my experience that oil filter cap wrenches lift "up & off" -'away' might be the better word- the filter during removal.
I wonder if an exact fit tool like yours would stay in position?
I mark the new filter so I can easily follow it through the 3/4 to 1 full turn.
I have a bag of every filter wrench my Dad or I have ever bought, and a set of HF ones (minus the one that broke the spot weld). But for new cars or trucks I always seem to need to buy new ones. Pickup takes strap wrench.
Finding caps for Subaru aftermarket filters is a PITA, I found one that works well with OE and another that fits the Wix pretty good.
These are one of the filters I torque to 10NM, I wont try to remove or hand tighten the ones that are in "ring of fire" its an easy way to cut your hand badly.
I might put a torque wrench on next time and see how much force 3/4 turn takes.
Use a rubber strap wrench.. plenty of grip to tighten if you have wrist issues.
although 3/4? turn after contact is not much torque.
Those filter pliers are great for removing.. however I dont like scratching or denting a new filter if I was going to use it to tighten(such as OP)
The wrist issues are funny. I can turn a wrench or swing a hammer, no problem, but anything that requires a wider grip, like opening a jar or turning a filter, and I feel it up my arm for days.
