Copper-based antiseize is very difficult to find here, though I now know a place in the next city where I could buy a kg tub of it, which would last me until the heat death of the universe.
I make aluminium-based antiseize (which I've never seen here) as follows. Put a tiny dab of your grease of choice in the base dimple of an (empty, or at least unopened) beer or soft drinks can.
This is your mortar
Roll up a wee ball of aluminium foil, the finer the better.
This is your pestle
Rub the pestle around in the mortar until the grease looks dark gray enough. Then scoop it out with your finger and apply.
If you don't want to get your finger dirty, wear gloves (or use a plastic bag) but you were probably doing that already, you big Jessie.
Course you lot can just drop in to Walmart, or wherever, but you might get caught out sometime.
This is your mortar
This is your pestle
