Importance of Bypass Valve Setting
NW Ohio
I'm looking at various filters for my IHC tractor. The Wix application lists a 51768 but some other manufacturer's applications cross over to the Wix 51283, which fits a Porsche application. The mounting is the same for both but the Porsche app is a somewhat larger filter. No Beta is shown but the tractor application showns the nominal micron rating at 25 while the Porsche shows 19. I would go for a larger filter that catches smaller chunks but the big difference in the specs is the bypass setting. The tractor app lists 10-12 psi while the Porsche app is 28-30 psi. Interestingly, the K&N filter (HP-4004) for the Porsche is listed as 8-11 opening and crosses over to the tractor app. Would I be shooting myself in the foot going for the Wix Porsche application?
I'd stick to specs as close to OEM as possible. Don't cross-reference a cross-reference. Always start with your particular engine when looking up various brands of filters. Filter makers often make compromises when recommending a filter for a certain engine, and going from one aftermarket recommendation to another may get you compromises in specs that are too far away from the engine designer's spec.
Ken
OEM specs aren't known.
Because media type and area need to be considered, I wouldn't x-reference between different brands. But, I would x-reference different PN's within a brand(or clone).
Also, the actually definition of the bypass PSI is not defined. Every brand can define the same PSI a different way and get different numbers.
Use the closest by-pass valve setting to what the engine calls for..or OEM filter is spec'd at.
8-11 or 10-12 will do.
If you go the other route..report back..
