Impact Wrench Grease
USA NY
What grease would be acceptable for an impact wrench? I have Lucas green on hand. Prefer to use what is best for the impact wrench. It is a twin hammer design. Thank you.
I haven't greased any of my pneumatic impact wrenches/tools in over 40 years of ownership. I just lubricate them with a few drops of air tool oil a few times a year.
Snap-On was proud saying Red Line CV-2 was their preferred grease for their air ratchets, the 3oz grease they sold was Red Line.
I've rebuilt a few twin hammers. You're going to want to use a thin coating of a moly EP grease. But a lithium complex that's EP rated is also just fine. You're NOT going to want to inject grease into the hammer chamber. It's a waste of time and usually hinders performance. I know there's a grease port, but it's useless. If you want to grease a pneumatic impact, you need to split the case, clean the hammer with a solvent and manually apply fresh grease.
Most pneumatic twin hammer guns have two sealed chambers. The hammer/anvil/nosecone chamber and the pump body. The two don't mix. You need to keep up with the grease in the nosecone and use air tool oil for the bearing and vanes in the pump body.
You should use air tool oil at every use. Put a rag over the exhaust outlet and blow out the excess by operating the tool for a second or two.
IIRC for my classic IR guns thst have grease ports, it’s repackaged Lubriplate 105 grease.
