Impact sockets for impact air ratchet?
Upstate NY
My lovely wife is buying me a 3/8" impacting air ratchet for the holidays. Not a impact gun/wrench, a ratchet. It maxes out at 70 ft/lbs. My 3/8" sockets are all chrome and not impact. Should I be ponying up for a set of 3/8" impact sockets, or will the regular old chrome sockets be okay?
Probably ok if they are good quality. Cromoly i would not worry about, vanadium would be less of a choice, it it only probably sees 35ft/lbs of torque. Its the impact that might crack one , but i doubt it. If it does, its not fast enough to hurt you.
P.S. i just saw you state 70lbs of force, thats pretty good for a 3/8 ratchet. Still , i think its fine.
True, it's not like this thing is a 500 ft/lb impact gun driving off seized lug nuts. I've certainly applied more than 70 ft/lbs to chrome sockets before. Although that was a fairly constant force, not repeated sharp impacts like an impact mechanism will.
For 8 hours a day, the last 12 years. I have used non impact sockets on impact Guns. And you can count the ones i broke on one hand.
They Will be fine.
I can't see standard sockets having an issue. I bet I can exceed 70ft-lb easily on a standard ratchet if I wanted to. I've only cracked one cheapo socket, and that involved beating on the ratchet with a hammer to achieve that.
70ft-lb is nothing for anything stronger than eyeglass repair kit
the HF impact set is dirt cheap and I have never seen anyone have issues with their sockets.
70 ftlb sounds like the HF ratchet. Its low energy pin mechanism doesn’t hammer the sockets like a high power tool would but it will still pound on socket giving every corner a rounded look especially on the square drive end.
Its not the torque that damages the sockets its the impacting, bottom line is it probably wont break your sockets but if you want to keep them nice buy proper 3/8 drive impacts.
This one will ruin chrome sockets for sure.
http://www.tooltopia.com/ingersoll-rand-...CFdUSHwodngIEqQ
You'll be fine with the standard sockets. I have an air ratchet with about the same max torque and I've never even come close to damaging a non-impact socket.
Ive used the standard chrome sockets from time to time with my 1/2" dual hammer impact gun, and so far haven't broken any with that either.
An air ratchet or an impact? Cheap sockets break faster than high quality sockets.
Differing opinions here, but it would take someone with your exact brand and type of sockets and a similar air ratchet to really know for sure.
The good news here is big complete 3/8 impact sets don't cost big money like the 1/2" sets do. Use your chromes for a little while if you have to, but pick up one of the Sunex Master sets as soon as you can. I have their Metric master set and while I've only had it for a couple months, I really like it.
Its probably not a bad tool at all, post a reveiw of it after you use it a little. I do like that it uses a normal size air ratchet head.
