Image resolution change?
Out west
Has there been a change recently with image processing? I understand there likely has to be some compression since the default resolution for screenshots and photos these days is so high, but recent photos seem much blurrier than usual. It's difficult to read text on images people post. Thanks.
I’ve noticed this too with recent image uploads.
For example, diagonal lines on the car hood in the attached image below appear to be more jagged than they did in previous uploads from a few months ago:
I bought a set of Michelin CrossClimate 2 tires and Enkei RPF1 rims for my Accord from Tire Rack last year and was thoroughly impressed with the entire customer experience. They beat every other local and online shop's prices for a tire/wheel combo by quite a bit.
Everything arrived mounted, balanced, had all the necessary hardware (centering rings and thin profile Gorilla spline lug nuts), and were well packed for safe shipping directly to my house. I opted to install them myself so I could properly torque everything to spec.
Can you point to an example?
It might be dependent on how large in size the uploaded photo is to start with. If it's super large then the amount of resolution reduction could be more than if the original photo was smaller in size.
I have noticed the same thing but was afraid to mention it. Examples below...
Before donating to BITOG ...picture at the top.....
After donating to BITOG...
Bottom picture 😁 😀
Here's an example of a photo I uploaded in a post:
Properties of the original on my phone.
Properties of the uploaded and resized photo in my post above. The board upload retained it pretty well for board viewing considering the file size went from 673 KB to 157 KB.
Here's one. He clearly took a screenshot of the photo which reduces the resolution considerably, but if you zoom in, it's basically not readable.
It's an issue of dimensions/pixels in this case. BITOG forum automatically downsizes images to 1024 pixels, be it vertical or horizontal. Since the image/screenshot was in portrait (vertical) mode, vertical pixel count was reduced to 1024. To preserve original proportions (aspect ratio), this caused horizontal pixel count to be reduced down to 470, and that is clearly not enough resolution for content with so much text. The image has a lot of blank space above and below. If he had cropped those areas before uploading to BITOG, the result would have been much better.
Here is another example.
While it's still legible, you can see how degraded the text is.
It's just a lot to ask from a 1024 pixel wide image to clearly/sharply render so much text in tiny font. BITOG image uploader is configured to apply heavy compression to save on storage space and bandwidth, which is totally understandable. This works well for typical photos, but is not optimal for a lot of tiny text.
Image quality would be slightly better if less compression was applied, but then you'd end up with a file that's 4-5x the size. When you have to store and serve up tens of thousands of images, that's a big impact to your bottom line. Most sites charge for hosting high res/high quality images. BITOG does not charge anything.
If I recall from the last time I tried, I uploaded to another host and tried to link it here, and it still pulled the photo and copied and compressed it here from the image URL.
Now I understand that the upside is that in 5-10 years, the images will still be here, whereas all those photos uploaded years ago to Imageshack and others are all broken now, sadly. I've found some old threads with tutorials that were absolute gold, but they're lost because the host stopped serving the images. So I appreciate that this won't be an issue here.
This is an image hosted on Imgur directly, saved as PNG. If you open it up in a new tab and zoom in, you should be able to see more detail, but it's at the expense of file size of course.
Yup. I used to host my images on Photobucket. Now they're all held hostage, asking me to pay a monthly fee to get them reinstated.
That resolution is fantastic. Which command did you use to insert that?
When I've used this, it's been a while so I might be mistaken, I want to say it just fetched the image and hosted it here.
I don't use any of those commands.
I just paste a direct link to the image and wrap it in "IMG" tags, like this:
Code:
[IMG]https://i.imgur.com/TdZ9jwx.png[/IMG]
