I swear I have the worst luck...
Well, I went back and installed new screws this morning:
Originally Posted By: Vikas
Why are they necessary? Rotor is not going anywhere.
Unless locked in place by rust, a loose rotor will end up on an angle on the hub next time the pads are off.
This can cause particles to get trapped between hub and rotor when the rotor is pushed back in place again.
Those particles will cause the rotor to be out-of-true.
Out-of-true mean brake vibration.
Brake vibration means a comeback for the garage.
Comebacks not only cost money (and margin), but mean a dissatisfied customer.
Smart techs put those screws back.
By that logic, Hondas should have far fewer runout-induced pedal pulsation problems, but that does not appear to be the case.
Regardless I went ahead and installed new screws.
You're assuming that missing screws are the only cause of runout.
You're also assuming that installers will ensure the hub/rotor mating faces are actually clean before seating the rotor and installing the screws. It's my belief that many people (home mechanics, mostly) are unaware of the need for surgical cleanliness, and end up trapping particles between the faces when they install rotors; this would mean the rotors start their lives out-of-true.
Plus, Honda cheaps-out on brakes. Honda brake problems are mostly due to that. Missing screws just add another possible cause of vibration to the other ones.
