One of my Fords has the "special" 4.2 V6. I have fought the dreaded 171-174 lean banks. I have done manifold gaskets, and all hoses. I do not think it is a leak. It revolves around idling in cold weather, and I have had success with replacing or cleaning IAC, PCV,MAF, But it is back.
The 4.2(and 3.8) besides leaks, is noted for dirty intake from PCV and EGR. Some fault bad valve cover design?? The individual EGR ports plug from carbon and oil and force more exhaust gas into the remaining cylinders, creating a lean reading.
I just cleaned the intake again after running it 10 months since all the above work. I can't believe it is that dirty/oily again This was on dino 3k OCI with the last 20K on Synthetic 5k OCI. It is at 106 K.
The heated PCV valve was goopy (was changed at 70 K).I have cleaned every thing up, and hope the MMO will lead to cleaner PCV operations and ventilation into the intake.I will run it in the fuel during cold weather.
I have nothing to lose. I don't care if it implodes. I am tired of fighting it. I found my experimental vehicle when the light came back on yesterday(watch what you wish for)! My question would be: I am only 1K into a 5K OCI. I put a pint into 6 quarts 5w30 Super Tech Syn with no pressure loss noted. I plan to change the filter at 2 K. I see many of you do not run MMO a full OCI, do you see any problems with me going the remaining 4K?
Thanks, We will see what happens. While skeptical I promise to report back either way.
