I Can't Get This LIght to Go Away
VA
This error light is on my Daughter's '01 Lexus IS300. It's a rear tail light error. All the lights are working.
Brake lights, parking lights, side lights, signal lights, Both the trunk and rear glass light work.
Page 44 in manual gives guidelines to solving the problem but we have worked through those.
It stays on all the time when the switch is turned on. No codes on my scanner so I unhooked battery
to eliminate the light. Light came right back on.
Any ideas?
A big hammer.
No, seriously. Like posted above, check the whole socket assy for corrosion. Even a small amount can alllw the lighting to still be functional, but enough resistance to trip the code light. I had this very problem in my fathers old ram truck a few years ago.
I had an old Toyota tercel. One day the door ajar light came on. After looking for another issue for the tailights, I found it was a broken ground wire in the hatchback area. I wonder if it's something like this.
Had 2 IS300, a GS300, and GS400. All 4 vehicles had that light on when LED bulbs were used. Switch back to normal bulbs, check all of them. Including center brake light at rear window.
Check the front bulbs too, it's a universal light for the dash. My Camry has it on right now too.
the electrical system works on resistance and if it sees there's none then the circuit is open and a light is out or if there's more or uneven amounts of resistance then makes it think there's a short or wiring issue since something is dawning more or less current. Make sure all the bulbs are identical or just replace them. also wouldn't be a bad idea to use a multimeter to check all the sockets.
Any ideas?View attachment 69235
License plate lighting?
My Son-in-Law did replace the 3rd brake light as it was out. He bought the bulb from AA. The light on the dash stayed on. I guess I'll start there.
Thanks!
If the failure light comes on when you turn the light switch on (not the brake pedal) it would be something to do with the tail or marker lamps. The bulb numbers / wattages must be exactly as specified.
Nick1994 has an excellent point to also check the front.
  • Like
Reactions: JC1
Clean them really well then buy a small pack of bulb grease, buy the OEM bulbs from the dealer if you need to
