I can’t figure out where my coolant is going
Elkins45
Site Donor 2026
Northern KY
1998 Chevy K1500, 5.7L V8. This vehicle has a whole bunch of issues even though it only has 56k miles so I’m not willing to sink much more into it than I have already. I can smell the coolant when it's running and I have to keep adding to the reservoir but I can’t see where it’s going. There aren’t any visible drips or wet spots when it’s running. I added UV dye and still can’t find the leak. There’s no white exhaust to indicate that it’s being burned.
Is it possible it’s just a small head gasket leak and that it’s being burned slowly enough it won’t show up in the exhaust? As I said it’s more of an academic question than a practical one at this point because the engine and transmission are about the only things still working.
An oil analysis would confirm internal leakage and could possibly save you from an unnecessary repair.
Just an FYI, if coolant drips on to something hot, it will evaporate and not reach the ground. I had a leaking water pump on my Jaguar, and never saw any evidence on the concrete. It would sit on the transmission and evaporate over time.
I’m in the “small head gasket leak” camp - not enough to see steam - but enough to cause a loss.
Get the engine hot with pressure on the system. That helps with locating an external leak. Check the underside of the oil fill cap for milky “pudding”. That would indicate internal leak (intake gasket). Avoid getting burnt but remove spark plugs with engine warm and pressure on the cooling system. A pressure tester is preferable. Have someone spin the engine over while you watch each bank of cylinders. You’ll see steam or slight moisture escaping the spark plug holes if coolant is leaking into a cylinder. That can indicate a cracked head or bad head gasket.
The plug will also be steam cleaned and look different from all the others
Radiators for this model year with the 350ci list ports for engine oil and auto transmission oil coolers integrated into it. Any signs of the coolant in either of those oils from a leak inside the radiator?
No, neither looks milky at all.
