hyundai throttle body replacement
texas
2018 santa fe 2.4. ok so i keep getting a tps code and actuator code. cleaned throttle body didn't help. about to replace it since the sensor and motor are all integrated. do in need to do a relearn procedure and if so which one? i have read it could be either a sequence of key on/off turns while others say to press the pedal. or will it relearn in its own. i've done some big jobs but never an electronic TB. any help is appreciated
Not sure about your very case but when I replaced TB on Forte (in sig) I just disconnected battery, replaced the TB making sure O-ring is seating properly, connected batt, let car go thru all its 'movements' with key in ON position before starting it and then just let it idle for a few mins before taking it for a normal drive.
Any time I’ve disconnected or removed an electronic throttle body, I’ve always turned the car on(KOEO) and waited 30-90 seconds before cranking it. Most cars will sweep the throttle blade open and close it, some will need an idle relearn.
