Originally Posted By: jake9364
Hi, my 2005 hyundai Elantra and 2007 hyundai Tucson call for Dexron Transmission Fluid. Can I use Mobil 1 Synthetic ATF Dexron/Mercon Automatic Transmission Fluid (1 Quart) in these cars.
Synthetic VS regular Valvoline MaxLife Dexron ????
The specified OEM ATF is SP-III, which is specified for Hyundai, Kia, and Mitsubishi vehicles, not Dexron. A lot of folks got paranoid about using other ATFs after Hyundai made a practice of denying warranty claims for transmissions using non-SP-III fluids.
In an elemental analysis SP-III looks much like Mercon V. Its visometrics look similar to ATF+4.
I have used Mobil 1, ATF+4, and Mercon V in these transmission with no problems.
Hyundai is now using SP4-M ATF in their transmissions and recommending it as backward compatible. This has visometrics close to Dexron VI which is "thinner" than SP-III.
If you want to go that way, Valvoline MaxLife DEX/MERC ATF meets the Dexron VI requirements.
You might also consider, given that the most expensive ATF is cheap next to replacing or repairing a transmission, the Red Line products.
Red Line D4 replaces SP-III and D6 replaces SP4-M. The advantage of the Red Line is a superior base stock which provides exceptional performance at the temperature extremes.
I've also used D4 in these transmissions with no problem at all.
