Hey everyone. This is just a maintenance item that I would like to replace along with the coolant / antifreeze. Since I will be doing a drain and fill with OEM Hyundai long life coolant I figured I could replace the T-stat also as Its original. I ordered a genuine OEM Hyundai Kia 82 Celsius T stat and the long life coolant is 25 dollars at the dealer.
I looked in the factory service manual, and it appears easy enough. Here's what the FSM says.
But that's the FSM... In real life is it this simple? Any special way to bleed system or anything?
Thanks for your input
