Chevy454z71
- Joined
- Oct 26, 2022
- Messages
- 53
@Trav When using hylomar on plastic and metal fittings do you let the solvent evaporate then put the hose on or just put the hose on immediately? Does the heat from a cooling system help it evaporate if you don’t allow it time to evaporate? I was running some tests on hylomar and when I put two pieces of steel together if I don’t let it evaporate first it doesn’t set up and make that tacky seal, does it seal anyway without letting it set up? When working with coolant hoses is hylomar universal blue or m better? The universal blue stays really tacky after solvent evaporation while the m gets pretty hard but still soft enough to seal something just not tacky with the touch of a finger.
