- Joined
- Feb 6, 2021
- Messages
- 1,368
Hey guys, so the Camry has very yellow headlights, a couple months ago I bought a bottle of hydrogen peroxide solution to deyellow them.
It did work! I will post pictures of them later, I do not believe I have before pictures.
Here is what I did:
----You need good amount of sunlight for this to work, you can apply it anytime, but it will take longer without sunlight. Make the car face the sun.
1.I cleaned the headlights of grime with that rain-x / windshield cleaner and rinsed with water.
2. I then applied this stuff with a paintbrush on the headlights (make sure to have a thick coating) : https://www.amazon.com/Super-Stabil...sprefix=hydrogen+peroxide+cream,aps,93&sr=8-5
If you get this stuff on the paint, clean it up with a wet rag.
3. I then took some cling wrap, make sure to cover the whole headlight and then use some masking tape to secure it
4. Let sit for like an hour or two
5. Rinse with water, and if you want, clean it again with that rain-x/windshield cleaner
6. you can repeat this process anytime, but remember to seal it with wax or something.
I will post after results and possibly before results if i have those pictures.
6. See results.
Here is what I did:
6. See results.
