I bought a steering cylinder from Amazon for my tractor. The shaft of the cylinder threads into a bracket attached to the front axle. The shaft is stationary and the cylinder is attached to the tie rods going to the front wheels. The only problem I have is that the end of the shaft with threads must be slightly undersized. I can't get it to stop leaking. I have tried several o-rings, Victor Reinz Reinzosil, hard-setting gasket maker, and nothing has lasted.
Is there a tape similar to plumbing Teflon tape made for hydraulics?
Any suggestions would be appreciated.
