Road sometimes gravel.Did we ever learn what 'type' of bike or terrain??? Road, hybrid, gravel, mtb??? KInda matters ya know.
I would say it then depends on your budget. Even the good mechanical disc brakes are more reliable and cheaper than the cheaper hydraulic brakes. If going cheap, I think mechanical is best and overall less hassle and maintenance. It takes a pretty good bump up in price to get hydraulic brakes that are solid and limited hassle. There's really nothing much worse on a bike than dealing with cheap hydraulic brakes that don't work right or fail outright. If going a bit more expensive, then hydraulic brakes would be nice, but not critical for road and gravel riding. Any disc brake is going to be orders of magnitude better than rim brakes of any quality or caliber.Road sometimes gravel.
I would disagree that ANY disc brake is better than decent V-brakes. For a casual rider, V-brakes will work for decades with the odd pad replacement, no worries about contaminating them with chain lube, etc. Sometimes the KISS is a better way to go if added performance isn't required. Atleast at the level I ride at, and with only 200ft descents, brake type isn't a large factor in rider speed. Back in the early 2000's I used to run some Ontario downhill races and could always finish in the top half with a hard tail and V brakes, back then it was about the drops(which I rolled mostly) for a lot of guys, but you make a lot of time in the corners... Once your at one finger braking(in the dry atleast) how much more do you need just to ride some trails?I would say it then depends on your budget. Even the good mechanical disc brakes are more reliable and cheaper than the cheaper hydraulic brakes. If going cheap, I think mechanical is best and overall less hassle and maintenance. It takes a pretty good bump up in price to get hydraulic brakes that are solid and limited hassle. There's really nothing much worse on a bike than dealing with cheap hydraulic brakes that don't work right or fail outright. If going a bit more expensive, then hydraulic brakes would be nice, but not critical for road and gravel riding. Any disc brake is going to be orders of magnitude better than rim brakes of any quality or caliber.
I don't think so. Hydro all the way.Did we ever learn what 'type' of bike or terrain??? Road, hybrid, gravel, mtb??? KInda matters ya know.
Brake Lesson 101 -I would say it then depends on your budget. Even the good mechanical disc brakes are more reliable and cheaper than the cheaper hydraulic brakes. If going cheap, I think mechanical is best and overall less hassle and maintenance. It takes a pretty good bump up in price to get hydraulic brakes that are solid and limited hassle. There's really nothing much worse on a bike than dealing with cheap hydraulic brakes that don't work right or fail outright. If going a bit more expensive, then hydraulic brakes would be nice, but not critical for road and gravel riding. Any disc brake is going to be orders of magnitude better than rim brakes of any quality or caliber.
https://www.mtbr.com/Brake Lesson 101 -
How would one know they have “quality” mechanical disc brakes versus “cheap” hydraulic disc brakes?
Is there a “Bobisthe BikeGuy” forum out there in two-wheeler land?
I don't think it matters much. Mechanical, hydraulic, Shimano, SRAM, whatever. They all work much better than brakes of the past, and require less maintenance. There are more important factors to base a bicycle buying decision, like the type of frame, size of wheels, and how well it fits.Looking to buy a new or used bike with disc brakes. Any opinions on type?
I always figured that the implementation of disc brakes on bicycles was more at the direction of the marketing department.
The trend for disc brakes is driven in part by marketing. They're "cool" and people want them. For the average all-around cyclist it doesn't make much difference, rim brakes work just fine. But disc brakes have some practical benefits for mountain biking, tandems, and other applications.Nope. Especially in mountain biking. Rim brakes are garbage and hydraulic discs are spectacular.
Agreed.The trend for disc brakes is driven in part by marketing. They're "cool" and people want them. For the average all-around cyclist it doesn't make much difference, rim brakes work just fine. But disc brakes have some practical benefits for mountain biking, tandems, and other applications.
- For biking technical trails, 1-finger braking is great, putting more of your hands on the bar. And less hand fatigue. The mechanical leverage required for this is impossible with rim brakes.
- With discs, if you break a spoke the wheel still spins freely and is rideable. Not with rim brakes.
- Putting the braking stress and heat on the rotor, not the rim, is A GOOD THING. Rotors are easily replaceable; rims are not.
- Disc brakes make carbon wheels viable; you do not want rim brakes with carbon wheels. Even though some bikes do this, it's a bad idea.
- Tandems are faster and have twice as much weight, which is more than twice the energy/heat to dissipate, so disc brakes are more effective.
This is only true if you don't have enough spokes. I have 36 spoke wheels for a reason.
I kind of figured that I might be the only one here old enough to have 36 spoke rims...Even on a 36 spoke wheel, if one spoke breaks, the rim usually goes out of true enough to rub the brake pads if you have rim brakes.
With some rim brakes you can adjust it wider to compensate. Others require tools for that.
It's surprising your lever didn't go to the bars before this happened.My mechanical disk on the rear ran over the peak of the cam on a downhill leaving me with only the front. It seems it needs careful adjustment so the the required level travel stays within the cam's ramp. It's a cheap ebike, would go for hydraulic next time.
