Originally Posted by tig1
Originally Posted by 4WD
Get the short turn with cast iron front axle ... lots of grease fittings and solid B&S Platinum ... no rust on my 42" deck 7 years and counting
I have that Mower(7 years old) and it does perform well with one exception. The engine is prone to blowing head gaskets. That happened to mine 2 years ago. After researching the problem, it appears to happen more often than I would like, as there is a narrow place where the gasket blows.
If that spot on in the head a minor resurfacing would fix it. If on the cylinder side,
there's more work involved.
No, that's not the problem. Where the HG blows is at a very narrow part of the head. Google it and it shows this.
Yep, the issue is that there is a section that has a thin area of gasket and no bolts around it.
