Husqvarna 550 XPG seized
Sweden (Stockholm area)
I bought a Husqvarna 550 XPG as a repair object and I dismantled it to check its condition. It turned out to have seized on the exhaust side, and the piston ring was stuck. There was a great deal of oil and soot, so it had likely been running with an overly rich oil mixture or the wrong type of oil. A new cylinder and piston have been ordered, so hopefully, it will be a working chainsaw again.
Back in the good old pre-synthetic days changing rings, pistons, and reed valves was common and parts were cheap. Today is a disposable mindset society. Don't fix things. Use it, throw it away and get a new one.
Kind of like "Why change the oil? It's a lease; I'll get another in 3 years."
Possible that it was cold seized. Or just run hard while set lean. The newer 550xp mkII is auto-tune. I don't know if that 550 was just a plain carb that was lean. I use a tachometer to set my high jets. The auto-tune doesn't need anything.
Did the intake side get scored too? That one is odd as I don't see the usual black/brown spot from oil breakdown. OE or aftermarket for the new parts? Looks like a fun resurrection.
Exhaust side only. Aftermarket parts for this one with a promise from the shop that its good quality parts so I will se how it ends :)
This is a auto tune. Here in Sweden all 550XP has been delivered with auto tune.
That’s a fun project! The 550 XP is definitely worth saving. It's hard to say for sure, but before you finish the rebuild, make sure to inspect the muffler for any debris or internal issues. Please keep us posted on how it runs once you get it back together!
That is not likely to be from too much oil. That appears to be a classic 'no-oil' situation.
A 4 corners seizure is generally insufficient warm up time.
A top of the piston seizure is often indicative of a too lean condition.
But no oil most often results in complete damage, like we see here.
As always, just a guess. There are times where the pattern is not set in stone.
Here is what a typical 'too lean' situation looks like:
And a classic 4 corners seizure, often from insufficient warm up time. Always take your time warming up a two stroke. Blip the throttle giving time for temps to equalize.
Just another note about piston seizures on two strokes. Any reasonable oil ratio and quality oil will work. However, insufficient octane can result in inaudible detonation, causing the piston to expand excessively and grab the cylinder. The most reliable way to operate a high performance two stroke is to use high octane non ethanol fuel and between 32 to 1 and 50 to 1, jetted properly. I use VP C9 unleaded race fuel.
Using 87 octane can be on the low octane edge for chainsaws.
Yeah why say over rich on oil? Agree with Cujet, classic no oil added to the gasoline.
That piston in the first post shows lack of lubrication.
Cujet, yeah lean overheat and some detonation as well, messed that up nicely.
I suspected there was too much oil because of all the soot buildup on the piston; the piston ring was completely stuck in its groove due to the soot. In the photo, the piston has been cleaned, and the ring moves freely now that the soot has been removed. It was likely the wrong type of oil, too, as the crankshaft had a strangely sticky oil residue. It is also possible that the engine seized due to a lack of oil, and someone then tried to salvage it using an additive or some other junk that caused the soot buildup and seized the piston ring.
Soot from 2 stroke oil sounds like that silver bottle stihl stuff.
