T435: Engine runs and passes visual bore scope inspection but will not rev up. Almost like the muffler is plugged. I will need to do extensive disassembly to get to the exhuast port to clean it, then there is always a chance it needs a carb replacement. This saw is complete. Is this worth doing?
450: This saw is not complete, someone took it all apart and the cylinder and piston is exposed. It is in good condition, im not sure why they suspected a problem with the piston and cylinder but id need to continue the tear down and re-seal it. Then source all the small tid-bits that are missing. I think this might be worth the effort but not sure. Need your opinions on both of these.
