David,Yes it is the same approach. Thanks for asking.
David
Could you please add a PDS to the Differential Life gear oil. It would be helpful to see the specs on this lube.
Sam
David
It is a HP gain, via friction reduction… HP at the crank doesn’t win races, HP at the tires does. Not one single racer is going to complain nor care where extra HP to the tires comes from, other than so they know how. It’s been said NASCAR teams have spent upward of $100k per HP when they’re at the level they are, so to pick up $200k worth of gains for $35 in gear oil seems like a bargain.You said HP gain. Gear oils don't improve the engine's output. That's at the engine itself. All friction reduction can do in the drivetrain is reduce losses.
Please post it on the Advanced Lubrication site.Sam, I will get that for you.
It's not a HP gain. It's less of a drivetrain loss.It is a HP gain, via friction reduction… HP at the crank doesn’t win races, HP at the tires does. Not one single racer is going to complain nor care where extra HP to the tires comes from, other than so they know how. It’s been said NASCAR teams have spent upward of $100k per HP when they’re at the level they are, so to pick up $200k worth of gains for $35 in gear oil seems like a bargain.
Who said crank HP anywhere? Obviously not me. And my statement is true, crank HP doesn’t win diddly. HP at the tire does, and any gain at the tires is a HP gain in the actual sense. Every HP picked up at the tires, whether a true gain or simply a reduction off loss, WILL make the car faster; something that can not be definitively said when dealing with crank HP. We don’t race engine dynos, we race cars.It's not a HP gain. It's less of a drivetrain loss.
A simpleton will take a wheel dynamometer and compare crank HP, and then claim it's a increase in crank HP, which is actually a false statement. to go from wheel hp to crank hp relies on crude estimations. The correct comparison, is the difference in wheel hp, since that was what was modified.
Looks like HPL has just released a Differential Life Cleaner in 80W-90.
@High Performance Lubricants, is the guidance for this similar to the engine cleaner? Use Differential Life in a clean diff, and this new cleaner in a neglected diff for a safer cleaning over time?
I'm restoring a car that had a plugged front diff breather, which resulted in light sludge coating everything...
Amazing! I, too, am interested in keeping my diff as clean as possible. It sure does work hard and could use some cleaning. Same approach as the EC, it is DC.. Got it.Yes it is the same approach. Thanks for asking.
David
I did go ahead and get the Motul 300. I put enough miles on my car.. I needed that piece of mind. And I have been known to drive HARD.
1. Got the "wrong Motul?" Looks like I might not have got the Gear 300 which is "the good one." I got "Motyl Gear." No 300. So. Fail, on my part.I thought you were a Motul guy. Just a couple of weeks ago you posted this:
Oh no...Got the "wrong Motul?" Looks like I might not have got the Gear 300 which is "the good one." I got "Motyl Gear." No 300. So. Fail, on my part.
I saw this a while backCurious if there is any "first change" advice for using the gear oil like there is when using the engine oil?
Not expecting any crud, but should it be an extra short first interval? 10k or so?
HPL Manual Transmission Life is the product you're looking for.I'm just trying to get HPL gear oils straight in my mind. I've been using Redline gear oil for years with excellent results but I've heard amazing things about HPL. I'm not that familiar with them and didn't see them listing if gear oils were GL4 or GL5. This is what I've been using in my cars and I'm curious as to what is the proper HPL oil to use. Thanks.
1. Redline MT-LV GL4 70w/75 Transmission Gear Oil
A: 2023 Toyota GR Corolla
B: 2017 Toyota Corolla iM
C: 2009 Toyota Turbo Corolla S
Thanks, that seemed like the logical choice. The GL-5 gear oil for the transfer case and rear diff was less clear to me.HPL Manual Transmission Life is the product you're looking for.
I just changed the transmission gear oil with some fresh Redline MT-LV in my GR Corolla and 09 Turbo Corolla. I figure when I run out of it I'll order some HPL. I've got less of the GL-5 75w/85 gear oil for the transfer case and rear diff of my GR Corolla and nothing said that it was a GL-5 rated oil.I’m running HPL Manual Transmission Life 75W in the Denso M56 in our Volvo S60.
The shifts are easy but firm.
I ran it for 8,000 then changed. I plan to change every 40,000 miles going forward.
Sam
I've been reluctant to try anything other than Redline MT-LV in the transmission since I've had such excellent results with it over the past 15 years. I'm very intrigued by the HPL though and for the transfer case and rear diff I'm very interested.If and when I place my next order I’m going to try their gear oil. I’ve tried just about everything over the years and can’t say I’ve really had one jump out. My current fill is royal purple. Between using a different style of plug with royal purple XPR 5w20 and max gear, my cars averaging better fuel mileage. Nothing earth shattering but I’ve went from 27.8 to 29.1 on the same trips versus this same time last year. Last years run was Schaefer’s 0w20 and their 75w90.
