Originally Posted By: Shaman
Both the intake and exhaust are amazingly simple. Under the car you can follow the pipe straight back to the fuel tank. Seriously just a straight pipe. The Preturbo intake is the box, then two 45 degree angles to the turbo. Unfortunately, most exhausts I have seen cost upwards of $700, and the sound most of them make makes a fartcan honda sound like an 5.0 with h-pipe and flows. I don't plan on racing, so I figure I will just keep the meth kit tuned up, and the IC sprayer fueled, and be happy with maybe a psi or 2 extra boost. It's a 1999, so there is no JOBD(Japanese equivalent of OBD2), and the tuning choices are again, more than I want to pay to get the extra bit out of it. To make it fast, I could buy a bike and then not have to worry about making it fast.
BuickGN, I need to start the controller fully open, and then screw it in from there right?
Yes. You don't want it to control peak boost, you just want it to open right before the wastegate setting. I do it in small increments just to be safe. Basically tighten it until the boost spikes or goes higher than the wastegate setting and then back off a little.
Just to clarify, this is the spring and ball type with an adjustment screw to adjust spring pressure, right?
If this was the bleeder style, a controlled vacuum leak, disregard what I said.
