This summer I'm going to camouflage my little Ford Ranger. I want to do it with spray cans only and I'll be using a three or four color military pattern I've obtained online. I do not want a hunting pattern or a stensil kit. Does anybody out there have any suggestions or ideas to make the task turn out properly? I am not much of a painter but I have done many scale aircraft models. From what I know I need to sand the clearcoat off with 80 grit. Then apply three coats of primer. Then, use a sanding block with 120 grit. Next, using an olive green (Krylon camo series) base, spray the entire truck that is to be painted (after masking of course). Then use the next color (light green) and free-hand the pattern (I want a blended, 'misty' edge between colors). I will use two coats per application. Thirdly, I will apply the sand color using the same free hand method. Done....except for one major question......since I will be using a flat paint, should I use a flat clear coat (assuming they have one) over the entire paint job or leave it as is?
Thanks for any ideas.
