quote:
Originally posted by Yuk:
Thanks Babaloo, you asked one of my questions. Please keep us posted as to how things go. If you're successful I'll go the putty knife route too.
No, no. Dont use any type of putty knife or screwdriver, unless you want to risk scratching up your mating surface......
This is what I have done, a couple of times, mostly on older land cruiser ranging from 1972-1985.
1. Drain oil. Kind of obvious, but.....
2. Remove all the bolts from the pan.
3. Get a piece of wood, and a bottle jack. Every toy pickup/truck has one, so I'm sure other manufacturers use them as well.
4. Using the inside frame rail, or something else sturdy in the area, wedge the bottle jack and wood if needed between the frame rail and pan.(wood is only used if the jack can not reach both places, use the wood to extend the reach)
5. Apply preasure until the jack stays between the two areas on its own. Go a little tighter after that.
6. Gravity, and the sidways preasure will have the pan off by morning. If oil spills are a concern, I guess you could leave a couple fo bolts in the pan very loose to catch it.
Works for me everytime, with no risk of marring your mating surfaces.
Good luck
Joe
