So, I'm still new to the game, but it's obvious that high amounts of silicon, in the form of just plain old dirt, isn't good for your engine.
Let's say you buy a used vehicle and the engine appears to be clean, no sludge or inordinate amounts of carbon deposits(though possible) and perhaps light discoloration from years of use, but you get a used oil analysis and the Si reading is high, but you know you haven't done any work on the vehicle that would cause for a raise in Si(that is no sealant etc).
How do you go about removing the silicon? Do it before performing extended OCI? A flush additive that you introduce only to idle for 15 minutes before changing the oil? Go to an HD or High Mileage oil for a short interval, for a few short intervals? Don't worry about it and you keep up with maintenance from now on(making sure intake doesn't have a leak/air filter is doing its job)?
