Originally Posted By: sasilverbullet
Originally Posted By: rustypigeon
Originally Posted By: Donald
Gravity is faster/easier than people think.
How long would it take to flush all 4 lines using gravity?
I have only done the pressure tank method and the helper push pedal method.
I'd like to know also...
I did my Liberty in less than an hour. I jacked all 4 wheels off the ground. I used a turkey baster and got as much brake fluid from the master cylinder as I could, and then filled it with fresh clean brake fluid to the top. I have 4 joint compound buckets cut to about 8" tall and slid them under all 4 rotors, and opened the bleeders, to slowly trickle brake fluid. I increased the flow, so that I was able to keep the master cylinder topped up without any problems. I ran a quart of fluid through. When I ran through almost the whole quart I over filled the master cylinder with the remaining brake fluid in the quart and closed the brake lines. I left the left front bleeder open until I had the fluid level to the full line and closed it. I loosened the rear bleeders first, then the fronts. The flow of the fluid with the bleeders almost fully open wasn't crazy, like I thought it might be.
