- Joined
- Nov 29, 2009
- Messages
- 10,258
So I have a jetski that doesn't want to run right. It runs lean all the time leading me to suspect it has a partially clogged jet or two. Last time it was just at idle and now it boggs down past half throttle. Sometimes it will do full throttle if you blip the throttle but mainly surges between half and full throttle if you have it down all the way. Anyone tried that b12 berryman chem tool stuff to put in the tank? I was thinking of running that and seeing if it will clean things out. This has been an on going issue for the last month or two. The last time I had it had I ran it hard enough that it blew out whatever was clogging it. I always use stabilizer in it but the ski really doesn't get used enough so it's kind of a recurring problem. Anyone know of any good additives I can put in the fuel cause I really don't know how to clean the carbs when their is more than one and they want like 500 bucks to do it.
