How to drive CVT
Virginia
That is my question.
I've driven manuals, autos for 55 years, a CVT scooter for 20.
Now the wife has a 24 Prius AWD, and I don't know what to do, mostly for longevity!
Do I?:
Simply select an input (say 40% throttle) and HOLD that until I reach my terminal speed, or
Vary my input, like a real car? (Low RPM right after shift, and 'rev up' as/with speed increases.)
My gut says select an input rate and hold, so the controller and I are not reacting to each other (maybe a learned behavior from scooter?). But then, maybe the scoot had maybe a $50 transmission, and this $5K?
Long life is goal, economy takes care of itself, it's plenty quick at that single rate.
Anyone know what's best?
Drive however you want, it doesn't matter. These don't even have a traditional CVT like you're thinking, these use a planetary style with an engine input and two separate electric motor/generators, and it varies the speed by spinning the two electric motors at different speeds to change the ratio.
I like to put it into gear and go. :cool:
Honestly, I just drive it. I might baby it a bit more, but... it really rewards with the mpg when I do.
Maybe drive it a bit less in WOT, out of FUD. That said, when WOT is demanded (passing), just do it. You don't list what it is, but as long as it's not a Nissan Jatco or maybe one of the Subaru's, it should be just fine.
This Guy does fantastic videos of how these kind of things work...
This one isn't exactly the Model of trans in your Prius, but the broad strokes are pretty similar across the Toyota line ( and to a certain extent, Ford, and the Chrysler Pacifica)
It's a geared cvt not a belt/chain one. If it's a belt or chain one let it roll before touching the gas and once it starts to accelerate you can go down a bit and hold or gradually go down. If I take my foot of the brake on the outlander sport and quickly accelerate even lightly it jumps a little but doing that in a torque converter automatic doesn't do that. But since it's a fully geared ecvt with no torque converter or clutches drive it like anything else.
The one thing with CVTs is that you should stay on top of the fluid changes. I don’t think that they can handle neglect like a conventional automatic transmission
You drive a CVT straight to the bone yard where they all belong.. Melt them all down. Then design a real transmission , and use the molten metal to make transmission cases out of them.
Does anyone remember when driving a car was simple?
Don't overthink it.
It's a Toyota CVT, I wouldn't worry too much. Maintain it, and you'll be fine.
Just put it in D and drive, the car will figure it out, as will you.
Enjoy that Prius for many years to come! Cheers! 🍻
