Originally Posted by jetmech1
Originally Posted by rooflessVW
Take a AAA and two test leads. Tap the leads to the + and - poles of the battery. If the speaker pops out, you've got it correct. If it pops in, the polarity is reversed.
That will tell you the polarity of the speaker itself. Believe the OP is needing to determine polarity of unmarked speaker leads.
From your description, it sounds like they used speaker leads with same outer jacket color (or did they use clear)? Either way, IF they did use speaker wire, does each lead have 1 copper appearing conductor and the other silver? Generally, the copper side is used for + polarity. If both conductors are same color, then look closely at the outer insulation jacket. Normally, one side has ribs or a line running along the outside and the other side is smooth. Ribbed side is +positive.
To isolate/find each speaker location, do it this way: Disconnect all speaker locations. Then
one at a time twist 1 speaker lead together. Go to the head unit and set your multimeter on beep continunity and one at a time find the speaker lead that has continunity. If your multimeter doesn't have beep setting, use RX1. Only the speaker lead that's twisted should have continunity. Mark each lead using this method. BTW, if you can't determing which conductor to mark as + pos. get a length of any good flexible wire (any gauge will work 20,18,16 etc) long enough to reach from the head unit to each speaker location. Connect it to 1 side only of each speaker lead and then connect your multimeter to that "test lead" and find which of the 2 speaker lead conductors shows continunity. Make that your + pos. lead. Finally, assuming your new stereo has a CD player, this inexpensive tester works like a champ at testing correct phasing once everything is hooked and playing here is a link.
Speaker phase tester Amazon
GOOD LUCK!!!
Well, I went back and re-read your post and realized that you probably don't have the speaker ends exposed. The 9 volt battery does work great IF you can see which way the speaker cone is moving. You can also make the speaker produce an audible pop by "dancing" the wire across the battery terminal. Can determing each location that way.
Trouble is, you indicate you're working solo. You're going to have to have loooong pigtails from the battery so you can watch each speaker move. However, having installed "systems" for decades, I would highly recommend upgrading the speakers if they're 90's vintage. Auto speakers take a beating and their sound reproduction really degrades with age. Most likely those cones are ready to go if they already haven't. Being garaged does extend this some, but if they're the OEM or even been replaced in the 90's, I'd really consider upgrading them so you have a fresh system.
