How to Clean Oil Stains from Cement ?
PNW
I tried Dawn dish soap with hot water and a scrub brush but it did nothing to remove oil stains from my cement drive way - your experiences how to best remove ?
I've seen some folks have success with a weed burner / propane torch, but I wouldn't do it if there's any moisture in the concrete, it could pop a chunk up.
I use a citrus cleaner, with a brush to agitate it and work it into the surface keeping it wet. I let it soak for about 30 minutes then power wash it out.
I boil water and dribble it on the stain to heat it up. Get a bunch of water boiled up.
Don't just dump the hot water on the stain as it runs off without departing the heat.
Then I shoot the stain with Purple Power. I'm sure the other modern cleaners -Simple Green/Orange Power- would work too.
Rinse and repeat.
I wet the region around the stain so the "dirty rinse water" doesn't stain any concrete downhill from the original stain.
I do want to try the "Pour N Restore mentioned above.
