How to Clean Oil Stains from Cement ?
PNW
I tried Dawn dish soap with hot water and a scrub brush but it did nothing to remove oil stains from my cement drive way - your experiences how to best remove ?
I've seen some folks have success with a weed burner / propane torch, but I wouldn't do it if there's any moisture in the concrete, it could pop a chunk up.
I use a citrus cleaner, with a brush to agitate it and work it into the surface keeping it wet. I let it soak for about 30 minutes then power wash it out.
I boil water and dribble it on the stain to heat it up. Get a bunch of water boiled up.
Don't just dump the hot water on the stain as it runs off without departing the heat.
Then I shoot the stain with Purple Power. I'm sure the other modern cleaners -Simple Green/Orange Power- would work too.
Rinse and repeat.
I wet the region around the stain so the "dirty rinse water" doesn't stain any concrete downhill from the original stain.
I do want to try the "Pour N Restore mentioned above.
I pour a little gasoline on the spot. Scrub it with a push broom, then hose it down. Not recommended for closed in areas.
Depending on how bad the stains are, but if BAD, I use carburetor parts dip. Keep the spot wet for an hour or so, then take a stiff steel wire brush, and scrub as hard as you can. Reapply the sauce, and do it again an hour later. Get the "good stuff" carb dip, like Berrymans Professional. That stuff sinks really BAD, so be warned. It cleans well though. When done, you will have a bleached white spot on your driveway where the grease was. No waterbased citrus or similar cleaner comes close.
On concrete I've had good results starting with Acetone and rags followed by Totally Awesome cleaner from the $2 store and a stiff bristle brush. Pressure washer just pushed it around for me.
Acetone helps on stubborn deep oil stains but I haven't found anything to remove all.
I use powdered cheap laundry detergent mostly. Sprnkle, wet, stick brush scrub and let air dry 24hrs. Work pretty good on most and not too spendy.
A big bag of inexpensive clay cat little as all I have ever needed but must be left on the stain a good while.
Clay cat litter, not the self clumping kind, the old school clay stuff
Pour some down, put on some cool music, dance on it.
Not kidding, grind it it.
Then sweep it up…
