I have a 2000 yukon xl 1500 RWD that has seepage from the rear diff cover. This unit has drain and fill plugs, and before I drained it, I wanted to make sure I could get the fill plug off. Well it came out fine, but the hole is too small for me to fit a finger inside, which is a problem as the owners manual state the fluid level should be 5/8 to 1 5/8 inch below the filler plug. For the 2500 model it is listed to be 0 to 3/8 inch below the filler plug. And it says, "only add enough to reach the proper level."
So without being able to feel inside the hole, how will I know when it reaches the proper level? Build a dip stick? I don't want anything to accidently fall of inside there.
Thanks for any suggestions.
Bill
Bill
