This is along the lines of the heaps of oil “reviews” on Amazon. “ I change this oil at 5k and it came out the same color as when I put it in!! Awesome oil, 5 stars!!”
From what I understand, having the cylinders deactivate causes oil consumption due to the rings having zero pressure/tension on them. Regardless of cause, I do not want a vehicle with cylinder deactivation. I have seen my father as well as some friends have some issues because of it. All of them consumed oil.I'd like to know too.
Thinner oils (less HTHS viscosity) don't give as much MOFT between moving parts, therefore there can be more wear over time. Running thinner oil isn't about "damaging engines and resulting in dead cars on the highways" ... it's about not providing as much wear protection than thicker oils. More HTHS means more MOFT and therefore more wear protection - the basic backbone of Tribology.Always comes down to this - if thin oils actually damaged engines we'd be seeing tons of dead cars on the highways.
Exactly.Thinner oils (less HTHS viscosity) don't give as much MOFT between moving parts, therefore there can be more wear over time. Running thinner oil isn't about "damaging engines and resulting in dead cars on the highways" ... it's about not providing as much wear protection than thicker oils. More HTHS means more MOFT and therefore more wear protection - the basic backbone of Tribology.
Put some 0W-8 in your engine that's speced for xW-30 or xW-40 and see how mechanically healthy it is at 200K miles.None of this would be the case if 0W-8/16/20 oils damaged engines in your average grocery getter sedan/SUV/truck.
Ford finally bumped the recommended/speced viscosity for the Coyote from 5W-20 to 5w30, like it should have been from the beginning. The increase in viscosity wasn't because of CAFE, lol.I've also seen ford vehicles with the same engines in Australia using 5w30, compared to 5w-20 recommendations in the US.
I thought we had some clown on this site doing just that or I could just be wrong.Put some 0W-8 in your engine that's speced for xW-30 or xW-40 and see how mechanically healthy it is at 200K miles.
Someone here ran some 0W-5 racing oil in a high HP V8 and the used oil analysis (and I believe some filter debris inspection) on a short OCI showed it.I thought we had some clown on this site doing just that or I could just be wrong.
Yea I thought we had someone claiming the benefits.Someone here ran some 0W-5 racing oil in a high HP V8 and the used oil analysis (and I believe some filter debris inspection) on a short OCI showed it.
What about my post suggested using an engine oil that is thinner than what the manufacturer calls for? The point was that when used in engines that call for it, those oils are very likely not causing issues.Put some 0W-8 in your engine that's speced for xW-30 or xW-40 and see how mechanically healthy it is at 200K miles.
Sure. No argument there. But then my question becomes "Will the average owner of an average car see a real-world difference in how the engine performs over a long period of time."Thinner oils (less HTHS viscosity) don't give as much MOFT between moving parts, therefore there can be more wear over time. Running thinner oil isn't about "damaging engines and resulting in dead cars on the highways" ... it's about not providing as much wear protection than thicker oils. More HTHS means more MOFT and therefore more wear protection - the basic backbone of Tribology.
Never a good idea to go thinner than what's recommended - except for the W grade. Sometimes people go thinner on the hot grade, but that could be causing increased wear - see post 50 for an extreme example. Going higher on the hot grade, isn't a problem. Going lower on the hot grade could increase wear, or cause real problems if really too thin under hard use conditions like extreme towing or track use.What about my post suggested using an engine oil that is thinner than what the manufacturer calls for?
Like said earlier, "causing issues" is not the same as increasing wear, unless the increased wear is cumulative enough that the engine isn't as healthy at 150K+ miles (lower compression, excessive clearances, more oil use, etc) than it would have been with less cumulative wear. Lots of people think their engine is in "good shape" as long as it runs on all cylinders and doesn't burn much oil. Doesn't mean it may have some added wear going on. I've seen lots of pretty worn out engines still seem to "run good" while driving them around.The point was that when used in engines that call for it, those oils are very likely not causing issues.
You'd have to do a very controlled test study to know, and you'd have to define what the "average driver that drives an average car" is for the controlled test. If someone isn't doing much except just cruising around at relatively low RPM and load, then the recommended viscosity (basically talking about xW-20 and below) will most likely be fine. Still might increase wear slightly over time, but certainly wouldn't cause the engine to "fail" and "blow-up" as some may falsely "interpret" in these discussions. The slight increased wear as the moles pile up may or may not be noticeable from behind the wheel.Sure. No argument there. But then my question becomes "Will the average owner of an average car see a real-world difference in how the engine performs over a long period of time."
Yes, a thicker oil provides better protection. This is a demonstrated fact and like you said, the basic backbone of tribology. But over 100-200k miles, with decent ocis, will it matter to the average user? Will the difference in wear rates be enough to be seen?
That's where my post was coming from. It's not people like us. We're the 1% of the driving population that care enough to even do minor research, even if we end up using the same oil anyhow. It's everyone else. I don't think your average driver that drives an average car would notice.
I have two and they don’t consume oil …From what I understand, having the cylinders deactivate causes oil consumption due to the rings having zero pressure/tension on them. Regardless of cause, I do not want a vehicle with cylinder deactivation. I have seen my father as well as some friends have some issues because of it. All of them consumed oil.
What engines and how many miles? My father had two Chevy 5.3 trucks and they both consumed oil before the 100k mark. My brother has a Ram with the 5.7 that consumes oil as well.I have two and they don’t consume oil …
