Hello everyone. I recently bought a Honda K24A TSX engine with a 30 day warranty from a local JDM engine shop to swap into my Civic for more power and I was immediately concerned about how rusty the camshafts are as soon as I pulled the valve cover off. The intake cam is hopelessly rusted and the exhaust cam was somewhat rusted, but not horrible and I was able to mostly clean it up. I called the owner of that engine shop and complained and he was being a condescending jerk and insisted it's fine and made all kind of BS excuses for why he won't honor his warranty. I eventually got him to agree to try to clean the intake cam (the really bad one) if I drop it off, which he won't be able to with good results. However, once he sees how bad it is, I'm hoping he will replace it or give me a partial refund so I can buy a cam. I am going to give him the benefit of a doubt and not post the name of the engine shop yet and I will not if he makes this right and honors the warranty, which I don't see happening at this point.
Anyways, I am wondering if you guys think I did an acceptable job cleaning up this exhaust camshaft. I was able to remove most of the rust with 800 grit sandpaper and patience, but the lobes are still a little pitted from the rust. I am wondering if I can safely use this exhaust cam the way it is of if I need to demand that he replaces it as well. I know that 100% smooth is always ideal, but I still need to buy other parts for this swap and I am on a tight budget, so if he won't honor his warranty I can't afford to replace the exhaust cam unless absolutely necessary. Thank you all in advance, I really appreciate any advice you can give me on this issue!
